Αναρτήσεις - BMW F800 Riders Forum & Registry
Results 1 to 5 of 5
    Greco's Avatar
    Costas
    Athens, Greece
    Feb 2011
    '09 K1300S
    Υστερα απο έρευνα αγοράς παραθέτω τα παρακάτω που αφορύν αναρτήσεις για F800ST.
    OHLINS
    Αμορτισερ με ρυθμίσεις S46DR1S 750
    ελατήρια εμπρός 08751-90 σετ 180
    συστήνουν λάδι 10W.
    WP
    πίσω LOW 800 Ηigh 830
    εμπρός ελατήρια σετ 100
    WILBERS (απάντηση σε email)
    1x WILBERS shock absorber Type 641 Your Price: 699,00
    - type 641, with reservoir connected on the hose
    - rebound 22 times adjustable
    - compression level in Low- and High-speed each 22 times adjustable
    - preload adjustment with special key
    - 5 years guarantee
    - Order No.: 641-0807-00
    Or
    1x WILBERS shock absorber Type 640 Your Price: 499,00
    - type 640, without reservoir
    - 5 years guarantee
    - Order No.: 640-0807-00
    For both shocks you can also become the following option:
    1x Hydraulic Preload Adjuster Your Price: 199,00
    - Order No:625-0046-00
    For the fork:
    1x WILBERS fork springs Your Price: 99,00
    - progressive windings
    - a little bit harder than original, but also comfortable
    - 29 Years guarantee
    - Order No.: 600-0335-00
    1 x WILBERS front fork oil Your Price: 00,00
    - special viscosity for your model
    - viscosity 10
    - In 2011 1 litre fork oil is FOR FREE by a set of fork springs
    - Order No. 610-0010-00
    The shipping costs depend on the weight of the parcel.
    Wilbers shock absorbers are no stock goods but are built and set-up individually.
    Therefore in case of an order we need to know your riders weight incl. gear as
    well as possible operation to find the optimal adjustment.
    Further you can choose between two different designs:
    - BLUE LINE blue spring (red/blue adjustments)
    - BLACK LINE black spring (silver adjustments)
    Our production time is approx. 10-14 working days. In case that you need to
    have the products earlier we can build the shocks within 5 days. We have
    to charge 17,85 express surcharge.,
    HYPERPRO
    πίσω P/M FRSPS3732XX 800
    ελατήρια εμπρός σετ RSSBM01PRNN ή G2-R 25MM πρός 120
    συστήνουν λάδι 7,5 ή και 5W.
    Υποστατικές βαλβίδες Ricor intimator HP 200 , αντίστοιχα οι αμερικάνικες της Racetech ονομάζονται emulators FEGV S4301 NV στα 190 . H Racetech συνιστά λάδι 5W, χρησιμοποιεί δε ελατήρια της HP.
    Javier
    Athens, Greece
    Feb 2011
    Καλή δουλειά!
    Ακριβά τα πισο αμορτιζερ ομος
    Greco's Avatar
    Costas
    Athens, Greece
    Feb 2011
    '09 K1300S
    Ακριβά δεν λες τίποτα. Ολες οι πιθανές λύσεις ακουμπούν εύκολα τα 1000 ευρώπουλα. Σε μια δύσκολη εποχή βεβαίως βεβαίως.
    Giorgos
    Athens, Greece.
    όταν είχα το F800S είχα βάλει ελατήρια Hyperpro ελατηρια/λάδια μπρος και μόνο το ελατήριο πίσω.
    κόστος, 250 Ευρώ τα ελατήρια-λάδια
    και 150 Ευρώ περαστικά.
    Το αποτέλεσμα ήταν πολύ ικανοποιητικό, εδικά στο μπροστινό
    Greco's Avatar
    Costas
    Athens, Greece
    Feb 2011
    '09 K1300S
    Το αποτέλεσμα ήταν πολύ ικανοποιητικό, εδικά στο μπροστινό[/QUOTE]
    Είναι με διαφορά η οικονομικότερη λύση και απο οτι διαβάζω-ακούω με πολύ καλά αποτελέσματα. Εαν δε συνδιαστεί και με αποστατήρες (emulators) στα εμπρός τότε ή λυση αγγίζει το τέλειο.
    Το πρόβλημα όμως μένει και κοστίζει αν είσαι στα 50 χιλ και το πίσω παρέδωσε πνεύμα.
