Gerbing Liner to Accessory Socket - BMW F800 Riders Forum & Registry
Results 1 to 6 of 6
    JimJam's Avatar
    Foster City, CA
    Jan 2011
    '14 F700GS
    Has anybody actually tried plugging a Gerbing liner into the BMW CAM-BUS Accessort Socket and running it in the low to mid tempurature range only (so as not to exceed the amp amp max draw)?
    I do have a pigtail up front that connects to a Yuasa Battery Charger; anyone know how to get that to connect to the liner? Looks like the Coax to SAE adapter attachment below might do it - anybody know?
    I have a 2011 F650GS. I searched other threads on this but none seemed to address this exact question. Thanks in advance.
    ohg59's Avatar
    Raleigh, NC
    Jul 2010
    507 / 6 / 38 / 86
    '07 R1200RT
    To your first question, it might work, I have not tried it given I use gloves and a liner, which definitely won't work.
    Question two: that adapter should work, but you need to check the fuse rating for the Yuasa pig-tail. Some are only 3-5 amp.
    My Steed: 2008 f800ST low, Givi V35, SkidmarxDB, 'Glenda' Aux Lights, Mirror Extenders
    Vher's Blog
    Points: 48,469, Level: 100
    13,061 / 8 / 110 / 2177
    For the 400th time, it don't workee! Wire it directly to the battery. There are connectors that adapt one plug style to another. Get the right stuff from the get go and make it easy.
    It's not cheap to get the Gerbing stuff but it really works and ignore the farking BMW outlet. It's a joke.
    I spent a couple hours this morning watching folks spend many dollars getting Gerbing stuff at Irv Seaver cus they had 20% off. Too bad the heated boot inserts didn't fit. Dang!
    JimJam's Avatar
    Foster City, CA
    Jan 2011
    '14 F700GS
    Thanks guys and yes the fuse in the pigtail would probably be an issue. Now I'm leaning forwards going with the battery
    (BAT-LI-128MVKT) solution. For the same price of the controller + labor I could use get the battery (comes with controller) and also use the heating for bicycling, camping, etc. Also leaning towards the Extreme Element Jacket as I only own a leather one.
    Any thoughts on that?
    If the EE jacket is anywhere near as good as the rest of the Gerbing stuff, it will perform well. I gots the old style and new style wired jacket liners. Love them. They back their products well. The newer micro wire is really nice, heats up quick and the dual controller for the gloves and jacket allow for just the 'right' temps.
    Just DO IT.
    getgo's Avatar
    Kevin
    Wilmington, NC
    Jul 2011
    '11 F800R
    I just took the BMW accessorie outlet off and replaced with the gerbing socket. Now my f800r is good to go. Just wire up to the battery and disconnect the old hook up or outlet. Good thing there is a nice spot for the new socket. Hardest part was getting the nut loose from behind the port.
