I have just carried this out with a filter change. I read on here that the refill should be about 2.8 ltrs instead of 3 ltrs stated by the maunual. I confidently refilled 2.7 ltrs. I then warmed the engine but admittedly did not take it up to the fan cutting in.
Oil level is well over the max level. Even cold it is about 1/4" above the max level.
Will it go down?
Will it do any harm?
Will it go down?
